Was feeling pretty despondent over this crash ... it was my own fault for doing something I knew I wasn't ready for (again!) But worst of all it damaged the one part I never thought I'd break and eventually planned on using for something else.
But daughter went to bed on time and wife went to bed early...so I pulled up my sleeves....
This is the GPS (now temporarily back burnered) I took this as a reference to remember how I connected the "FTDI" cable:
(Side Note: I was able to get the GPS working with my "FTDI" cable which is actually a "Silicon Labs" cable since it uses a Si chip instead of an FTDI chip. But it was a cable I had on hand and was willing to hack apart. Not sure if it's actually configured correctly or not though.)
Next I figured I'd see if I could use my cable with the pro mini I had - so I just shoved the wires in the holes and clamped them in place with a Popsicle stick and clothespin - it worked! I was able to get MW2.3 uploaded to it:
So I started taking apart the quad to get the mega out for repair and get the pro mini wired in for the next few days. This was after I straightened most of the bent stuff on the mega. Looking at the board I suspect those two damaged caps aren't even used when powering it the way I am...so the crystal is probably the biggest problem with it:
With the quad this far apart I figured I should grab some detail shots of my hacked together IMU and how it's mounted. You can see the baro sensor at the top, the LLC board higher up and there in the middle is the sandwich of WMP and Nunchuck boards that makes up my IMU:
Wiring on the IMU is really ugly. But it's been working so I'm not in a hurry to mess with it:
Got pretty far tonight. Ran out of wood so I'll have to hit the store before I can finish reassembly. Went through the motors and found one broke a winding as well as the one that had all three wires pulled off. Will try to remember to pick up some epoxy when I get the wood tomorrow. Soldered bullets on the two spare motors and have them hooked up now, I'll have to rewind these two damaged ones and turn them into the new spares. I also cleaned up the wiring on the LED's and they're tied into the main harness much nicer now...unfortunately I also took out one of the SMT resistors on one section of lights, will have to see if I have any suitable replacements on hand:
Almost ready to finish physical assembly and test fly again...but for some reason I'm getting no gyro reading with the pro mini setup as it is right now. It's 1AM though and I need to get to bed so I'll have to try and figure that out tomorrow. What's odd is all the other sensors ARE working, and that's odd because the baro and mag are both 3v and I haven't hooked up any 3v yet since the pro mini doesn't have a 3.3v line like the mega did. I'm also not sure how I'm going to hook my bluetooth up on here yet. I'll probably do it the same way I hook up the "FTDI" cable - just four pins and a bit of popsicle stick to hold them in place.
The pro mini shaves a good chunk of weight off compared to the mega. But I think I like the extra options the mega gives...and it's 3.3v regulator is handy. Getting started the mega was definitely easier than the pro mini was tonight. But if I was building a quad without GPS the PM is the way I'd go for sure. Since I'm toying with the idea of doing a hex now that I have 6 motors the mega is still a nice option with it's extra pins.
Oh - I also looked at flashing my ESC's...it won't be easy, but I do have two fine enough tips for my iron that I could possibly pull it off. May wait until I order some easier to flash ESC's though so I've got spares in case I fry something. I really want to try simonk because I'm not at all impressed with the performance of these multistars in several ways - still my biggest regret in choices I've made building this.
