Hi everyone,
I already built an FT Explorer and everything went fine, the plane flies great.
I tried the FT Cruiser for my second build. A nice looking twin engine, how should I not be tempted
So, I balanced the plane before maiden flight, using a 2200mAh (260g). Everything seems OK, but the plane instantly flip over (nose up) as soon as I increase a little bit the throttle. It behave as it was very very very tail heavy.
Second try with a 5000mAh battery (470g. maybe a bit excessive
). The plane is - obviously - unbalanced, crazy nose heavy when using the CG marks. It does not really solve the problem, but at least I can more or less fly it...
I checked everything I can. Wings profile seems OK, tail is straight, control surfaces are properly aligned. The only modifications I did : added BBQ Skewer to the tail (same as FT explorer), and gave the plane a nice colored look using 45mic wing tape.
I desperately need some help here ! Any idea of what I could have done wrong ?
