Home again, home again, jiggidy jig . . .
when last we left off, the flying part of the quad was up and running, and minus a few cleanup points (final battery connector and covering exposed connections) she's "airworthy" . . . but No FPV.
Honest, I'm not trying to steal your tiny soul.
So next we pull out the camera, and like everything else, by necessity . . . it's TINY!
First things first, that cable will need to go. Hooked it up to test and determined the cable and mic are on the bottom of the camera. Good to know.
Space will be a bit tight for all that wire, so off it comes
Keep in mind, it's red (power), Yellow(Video), Black (ground), with Red nearest it's regulator. The white audio wire is left disconnected. Audio in FPV is pretty much a waste of bandwidth, particularly for multirotors. You'll get a cleaner signal off the video if audio is grounded, so I'm striping it off.
First version I did de-soldered the mic too. Second one I left it on. Mistake. In the next post, we'll mount it on the frame and leaving it on will prevent us from leaning the camera back for "warp speed".
Polarity strikes again!
If you recall from much earlier, the first camera got burned out from having a reversed polarity. since these connectors aren't hot-swapped, this is easy to fix via keying. effectively I add a pin to near middle, and fill it so the plug can't be plugged into it backwards.
First, to key, let's cut the key pin:
take care to save the little bit we cut off. We're going to use it to fill the keyed hole on the female side.
Slide it in and use the male side to press it into the connector. Viola! Now she's keyed.
Now if I press the male in misaligned to the keyed slot, the connector won't seat and I know I'm doing something wrong.
What's life without Connectors? Disconnected.
Now that we have a ghost of a chance to prevent reversing polarity, time to mount the header to the back of the camera.
First we prep it. Bend all the pins 90o to the mount. one advantage to these round milled pins is they can twist in their mount. twist all three pins so they match the pad spacing on the camera and trim them so they'll land flat on the pads.
solder pads are on the bottom and we want the connection form the top, so up and over the board it is. Spacing is tight so a touch of careful alignment . . .
. . . and a bit of magnification is called for:
flux, tin, tap 3 times and . . .
The camera is ready to mount into the frame . . . but more on that later . . . hopefully later tonight.
