ok. kinda bummed and need some input. not sure what is going on.
symptoms...
wing binds normal, has all control surface movement correct, problem is the motors and not spinning up even.
the left motor works as should will spin up normal and responds to rudder mixing properly. the right motor however will not respond to throttle until over 50% or 50% rudder.
i have verified the differential mixing, i have since used the exact mix on 2 diff planes without issues, so i know its not the "mixing."
i thought it may be an old setting from my first dart so i deleted the model, rebuilt it, and re-programed the mixing just to be safe. no change at all.
i thought it may be a throttle range issue, so i tried to set throttle range but had all sorts of issues with the right motor and esc. the left side worked as usual, throttle at full on tx, plug in battery, wait for 2 beeps, then close throttle to zero, then the esc sings it's little song and all is good. when i try that on the right side, i don't get the 2 beeps and the motor just goes instantly to full throttle. when i throttle back to zero, it just stops, no esc beeping, and i have full surface area control.
i also thought maybe throttle timing but since this esc has 1 wire missing, my programing card will not work.
any ideas guys?
gonna be really bummed if i have to scrap another custom skinned Dart.
thanks,
me
