*Unofficial* FT EZ-Glider
Hyper46havoc
Also if I was to build again with same board I would make the nose a little longer just so I could use less lead. I also added little blocks under the wing that go into a cut out on the fuse to align the wing. Putting servos on it and towing it up with another plane would be fun.
Paracodespoder
Decided earlier to put some servos and a little 1s in mine, took it out for its rc maiden a few minutes ago. It flew fantastic! Glides really well for its draggy wing and tail, next step is to add a motor (that I don’t have, so it probably will be several months till then) and use it as a landing trainer :p. This would be a good first plane for someone looking to get into the hobby, especially if they have a friend to carry them up on another plane and drop it.
kaighn80
how much thrust would it need to get itin the air (from a chuck obviously)? i was thinking of one of those little mini drone motors and a suitably small prop
