Yeah the Power Pack F 6x3 prop I think is a little big for a 12A ESC. Plugging it into eCalc, I get a max current draw of 14.1A on 3S. I ran an RS2205 with the 12A ESC and it also was not too happy about it so I limited my throttle to 80%, which measured out to 9.5A in reality. The prop's not very good for 2S either though, maxing out at 280g of thrust / 8A at full power. Better prop fits seem to be a 6x4 for 2S at 344g/9.3A and 5x3.5 for 3S at 435g/10A.
I have to say this Goblin flies really well and is a ton of fun. I scratch built one and kinda messed up the wing cutout assembly so I had one wing dipped lower that the other with respect to the fuselage. Not a big deal to fly with a slightly rotated body though, right? :-D Actually that appears to be true because it flew just peachy. I didn't bother to paint all of it because I am about out of spraypaint and just wanted to make sure the control surfaces didn't warp when they land in the swamp here.
If only it could make me a better pilot though. I cut hard into a low turn and it was clear that I didn't have the speed to keep it level so I gunned the throttle. Blackbox says at the same time I relaxed on the up elevator which didn't help my situation and I ended up with my Goblin looking like many in this thread. The time from throttle up to impact at full throttle, under 0.7s.
This was so much fun to fly I will definitely fix it up and fly it again but I kinda want to get more pro-looking version. I just can't decide on an FT speedbuild kit, a Strix Goblin or a Strix Mini Goblin. Has anyone 3D designed a side plate that can be sandwiched between the doublers and fuselage to give them more strength? A 0.5mm thick band of plastic glued in between them could help to spread out the force of nose-in cartwheels.
EMAX RS2205-2300KV motor, 20A Flycolor Raptor F390 ESC, 1000mAh 3S battery, Lumineer 5x3.5 prop, Omnibus F4 Pro V2 flight controller, 9g SG90 servos - 159g empty (no servos/motor/mounts) 382g all up weight
