BridgeInspector
Flite Test Groupie
My Flite Test Volunteer themed FT Legacy is easy to see.
What combination of motors, props and battery are you using?My Flite Test Volunteer themed FT Legacy is easy to see.
View attachment 122473 View attachment 122474 View attachment 122475
Now THAT is awesome!!
Well done man, well done!
P.S. Will I be able to sign it myself in July?
Thank you for the info, I have one of those H quads myself.My set up was from my decommissioned FT H Quad (if you have ever heard of that from way back).
________________________________________________________________________________
Motors: 2x 900kv 2215J Turnigy - not the most powerful, but they work ok, I would go bigger and may still)
ESC: 2x 30amp Turnigy Plush
Props: 10x4.5 (Green) - (not 100%,could be 11x4.5 but they are definitely green, ha)
Battery: 4s 2200 Aspec2
Group photo after the FT Legacy flight at FFO18.
This is the landing gear for the Legacy.
hey sponz!!!! do you have any dimension data for the landing gear as i am scratch building the legacy so thai i can make my own landing gear???
E]
Hello, I couldn’t find if it had been covered or not, but I have the hardest time using the bomb bay because of the direction it opens. The wind forces it closed even after you release it. Any tricks y’all have done to get around this?
is there a place we can order the landing gear josh says they sell it but I cant find it
I would use C motors. It is a heavy plane and you would need the extra power to tow easily.Would the Legacy be a good option for towing gliders? Would twin B motors be sufficient?
Dang. Twin B's is what I have right now. I was hoping I could make it happen (specifically towing up Tiny Trainers, the new EZ Glider, or even Sparrows). I haven't yet flown anything so big, and definitely haven't tried towing anything, so I'm glad I asked. I like the idea of the Legacy as a glider tow plane because it really encompasses the whole idea behind FT, Edgewater, and the Founders -- that is, working to build the community and get more people in the air.2m and under, probably yes.
2x B, Probably no.
Not sure this is the right thread to ask this, but I'm also curious about whether anyone has tried making/using different wings for the Legacy yet.
After a few weekends building (and waiting for radio gear), I finally got a chance to maiden my Legacy last night. I'm definitely loving this plane so far.
This is my first twin-engine plane and I'm really enjoying the yaw authority the differential thrust gives me; I've never been able to do hammerheads before but now can. I need to practice coordinating the other surfaces so that I don't pull out off-axis from where I started, but I'm loving it!
I built this one using the tape techniques from Experimental Airlines. The tape added a good bit of weight; I had to go all the way to a 3S 5000Mah battery to get it to balance. On the plus side, that means I'm getting 15-20 minute flights on a battery (that includes a good deal of aerobatics).
Looking for some suggestions on how to improve ground handling; it is a bit squirrelly and wants to do ground loops if I try to taxi at anything more than a crawl. Once I have it basically where I want it, with 45-degree flaps I can get it airborne without TOO much craziness by just punching it. It still yaws quite a bit, but gets airborne in about 5-7 feet.
I'm going to update mine using this;Looking for some suggestions on how to improve ground handling
