i should probably start a new post but...i'm lazy.
anyways, the prints mounted up almost perfect. spacing was absolute, fit perfect, prob was with the last design change i did not account for the depth and there is no room for the bolts that will mount it to the landing gear strut. hence the reason for quick prints, would have been grumpy had i invested 4+ hrs into a failed print.
the mods were a simple change and are lined up in the print cue. these failed prints were good enough for me to be able to mock things up. i am happy with size and was able to confirm placements and angles of the shocks.
dino is pretty happy as well. that's always a good sign.
i have upper mounts printing now. they will be done in 1.5 hrs. i will start the hinges after that for a night print. by morning i should have everything i need to proceed on the gear assembly and build of the plane.
next big step is cutting the gear legs from the center assembly and mounting the 3D printed hinge.
cross fingers 'cause i'm making this up as i go.
me
