FT Sea Angel
Designed By: Josh Bixler, Andres Lu, and Jeremy Andrew Davis
Plans By: Dan Sponholz
Description:Designed By: Josh Bixler, Andres Lu, and Jeremy Andrew Davis
This is the FT SeaAngel. The Sea Angel is a unique aircraft modeled after Porco Rosso’s plane from the 1992 Hayao Miyazaki anime film made by Studio Ghibli as well as the 1925 racing plane, the Italian Macchi M33. It's sure to be a head-turner wherever you fly it.
The SeaAngel is a scale flyer that can be can be flown 3-channel or 4-channel with optional ailerons. The build process is challenging, yet rewarding so if you are new to building this might not be the plane to start with. For a top-mounted motor design, the plane balances well. It is a good first seaplane and can help you learn to correct for torque when increasing throttle.
The SeaAngel is sure to be a conversation starter and a great way to make memories with friends and family.
This plane was designed as a collaboration between Josh Bixler, Andres Lu, and Jeremy Andrew Davis.
Power Pack Comparability: Power Pack C
Speed Build Kit: Speed Build Kit
Specifications:
WEIGHT WITHOUT BATTERY: 1.4 lbs (635 g)
CENTER OF GRAVITY: 2” (50 mm) from leading edge of wing
CONTROL SURFACE THROWS: 12˚ deflection – Expo 30%
WINGSPAN: 42 inches (1066 mm)
RECOMMENDED MOTOR: 425 sized 1000 kv minimum
RECOMMENDED PROP: 9 x 4.5
RECOMMENDED ESC: 30 amp minimum
RECOMMENDED BATTERY: 2200mAh 4s
RECOMMENDED SERVOS: (4x) 9 gram servos
FREE Build Plans: FT Sea AngelArticles: RC FLYING BOAT | NEW FT SEA ANGEL RELEASE!
Release Video:
Build Video:
