I ended putting the ESC on the bottom, and fairly far back on the pod. I have extra wire between the motor and the ESC. I also had to extend the battery connector wire. My battery mounts on the bottom of the fuselage, right against the landing gear. A 1300 Luminer balances nicely in there. I have a number of these for my quad, so that worked out well. By having the ESC fairly far back, it is near
the COG, and the throttle connector easily reaches the receiver. I mounted the receiver up high, near the COG and easily accessible via the wing saddle opening. I also needed to get the connector for battery voltage into the bottom of the receiver. I like getting that bit of telemetry.
Since I built mine so it can be a seaplane, everything had to be water resistant as well.
I used a bare foam doubler on the bottom of the fuselage where the battery sits. The velcro sticks to bare foam better than paper over foam. In my experience, the paper can come loose.
Still waiting to maiden. Maybe this week.
Mike
