Wow, Gazoo, that's a very nice looking Cubby. I think you can't go wrong with a bigger motor. You don't have to use all of it.
Thanks. I'm pretty sure I had a ski jacket in the '70s with those same colors.
Mine flew nose heavy. I pushed the battery as far back as possible until it bumps against the landing gear tab. It can stand a little tail weight so maybe a steerable tail wheel is in order.
I thought I saw someplace where someone dropped a C-pack or equivalent in a Simple Cub. I'm thinking that the nose weight would be a little much. Even with the slightly larger motor that I'm using, it is a bit nose heavy. Has anyone used a bigger motor? Please report.
Came home from FFE17 with a FT Simple Cub.
Weather permitting I'll get to fly it this weekend.
View attachment 94432 View attachment 94433
Here is my attempt at the FT Simple Cub. Fairly easy build and things went together well.
I noticed others complaining about the back of the wing folding and added some 3-D printed braces hot glued in place in the problem area. Seems to be holding up well and that part of the wing is very solid now. Also, I added some rubber band protection in the form of C-shaped pieces that cover the back edge of the wing.
Which is the best way to get a waterproof "boat" for the fuselage? Is it better with the water-resistant foamboard, or is it better to waterproof the regular foamboard with the water based polyurethane treatment?
I posed this question some time go. Instinctively, I have surmised that a hybrid approach might be best. WBPU and kraft paper for the hull, with water resistant foamboard for the rest of the plane.
I don't have water resistant foamboard, but I am going to make my Cub floats with the WBPU and kraft paper technique.
OK Gang,
I didn't add the DTF landing gear skirts because I fly off of a grass field. And being a newbie I've had a some "hard landings" and this has resulted in the wire landing gear getting abused (i.e. BENT! :black_eyed
So I bend it back but even with that "fix" I've been having a bit of a hard time taking off. So I'm probably going to make a new set of gear. But this time I wanted to add a set of bracing that would help to keep the gear more forward. They tend to bend back after a couple of landings (controlled crashes).
Now I realize that beefing up the landing gear will cause that energy from a crash to go somewhere else. I don't want to beef them up as much as stabilize them. That's why I was thinking of adding a set of braces made from wire and secured to the main gear via thread soaked in CA glue. I figured it'd be one piece and would be formed so that it would loop up and over a bbq skewer at the base of the fuse.
I was wondering if anyone else has done that.
I've looked through this thread and saw a couple of landing gear mods. But not exactly what I was talking about.
