Sure. Don't know what your previous flying experience is, but the Simple Cub (with standard control throws) can be a handful at first. If you're using it as a trainer you can dial down the ailerons and rudder for the first couple flights (I think my ailerons are 1/2 the low gauge setting) to make it more "cub-like". I plan on using expo settings at some point and adding flaperons into the mix (about 1/2 flap) for landing. I don't need any help with take-offs, with the B pack motor, a 9x4.7 APC prop and 1000mah battery this thing can take off in a couple of feet on grass (I'm using Timber 1.5M wheels).
Most of my flying has been with the safe stuff from Horizon. This will be my first plane with out safe. Still trying to get more experience & flying Sim. It may be awhile before I can fly it. I order Batts from HK and my order has been processing since 3/20 and this is from the US warehouse. No telling when they will arrive.
