What paint did you use? Also, did you do any prep of the foam board?
Very interested in the prep / paint method used for the cool ribs. For my process, I sprayed Krylon primer down on the Water Resistant foam board before doing the top coat of the Ironlak Sugar spray paint for the color. I've had multiple success doing this on white DTFB, but things didn't go as good this time - multiple issues with paint lifting.
Some lifts were from masking tape - and I apply all masking tape to my t-shirt first before applying to the plane to reduce the adhesive power of the tape, but it still didn't work in all cases. Other times I left the masking paper template sitting on the plane just a little too long and the paint started to firm up stuck to the masking paper and started to peel up from the foam board.
The common point with all the peeling is the Krylon primer loses adhesion to the WR foam board and come up leaving clean WR foam board showing. So the next one of these I do will get a whole plane 320 grit sandpaper rub down to help the primer out.
