So, just had an unfortunate and terminal incident with a roving tree and my Durafly Das UglyStik. Looking through the list of FT planes that I could possibly swap the electronics into, the Spear interests me the most. The donor motor specs are closest to the C pack at about 1100 kV, but it's a bit larger & heavier with a 35mm diameter can. The motor also has the shaft coming out the bottom, so looks like it can't be mounted with the motor on the outside. (I've not taken it apart yet to see if the shaft can be swapped to out the motor top yet.)
So, a couple questions for those that have built this...
I'm not terribly worried about getting CoG correct as there's enough room inside this wing to move stuff about as needed, but I am wondering if there's enough room inside the Spear power pod to fit a motor this large, and would there be any issues with a prop running very close to the fuse? (Other than maybe some higher noise and lower efficiency.)
Oh, and any issues I may not have thought of?
Thanks,
Mark
What kind of prop you want to use ?
I have a 3530/1100kv motor, running a 10x4.7 APC S prop, it fits in a 120% Spear, not on the original dimension Spear.
I printed the drawing at 120%. She fly great.
