Nice plane! I look forward to plans for floats, i'd use that, snow looks like its here to stay out here
Should do great in snow. I've been flying them off the grass in my yard, so if it'l do that, should fly off anything.
Here's the plans:
WWI Mighty Mini Floats - Beta v.1
These work equally well on both the SE5 and the DR1 triplane.
I didn't take any pictures of the tail float.
Oh well. It's the same process, just smaller and simpler.
Remove paper, bevel, and pre bend the foam a bit so that the curves match.
Glue in the side pieces one at a time.
Fold over the top piece and glue down.
Insert a wire support and make score cut through it in line with the top of the float.
Remove foam at the score cut.
Fold over and glue.
Seal it up with some hot glue. Wire for gear is inserted down into the wire support piece.
Stabbed a couple BBQ skewers through the main floats and sealed them in with hot glue before attaching the wire struts. Wire struts are fitted to the fuselage very simply by making a couple cuts horizontally (red line on picture) along the bottom of the fuselage. The tail float was installed with 3 short pieces of BBQ skewer. I stabbed them into the tail of the plane first, then made holes in the float inline with the skewers.
