TehMaxwell
Tales of a Rookie
I have been wanting to upgrade the set-up on my Versa Wing for a while, on my original set-up (1600kv Motor, 8 by 4 Prop, 20Amp ESC, 1000mah 20c Battery) I was only getting five minutes maximum on flight times and had to fly at around three quarters throttle all the time. I used thicker 9mm Foam at the time, as it was the only stuff I could find in the UK, the extra weight didn't help matters.
So I finally took the plunge a few weeks ago and bought a 30Amp Turnigy Plush Speed Controller and a Turnigy Park 480 1200kv motor, a significant upgrade which would allow me to run my larger 2200mah batteries. Then I had the idea of running two batteries in parallel, like I have seen on so many FPV airplanes. The stuff arrived and I cautiously cut into my versa wing, making the slots exactly the right size. After a bit of added soldering, it was all done!
I got the chance to maiden it today, it is like nothing I have ever flown before. I am still pretty new to the hobby with only a years worth of experience under my belt and only three different, quite mild planes in my hangar. But this thing is in a whole new ball park. It climbs easily at less than half throttle and rockets away at three quarters. It felt like it was going to rip out of my hand before launch. Plus, if I max it out I can get around 10 minutes of flying. But at around half throttle I can fly comfortably for around 25 minutes.
Anyone who is thinking about upgrading to a better FPV set-up and scrapping their Versa Wing for less exciting projects, I urge you to think again. This thing is awesome and costs way less money!
Versa Wing is definitely the right name for this airframe!
A few pictures to wet your appetites for an upgrade?
