Using LiPo's in Spektrum Transmitters
colorex
Rotor Riot!
Ok, so my friend Nick asked me for a solution. He uses a DX5e to fly, but he wants a longer lasting battery for it. I looked around and found this one for a DX8 ($17):
It is supposedly intelligent with LVC built in, but I don't know if it will fit in a DX5e.
Is it worth the money? Will it fit? Will it work?
colorex
Rotor Riot!
So the battery shown is a no-no.
So what's the best thing possible? As in longest use time without charging for a DX5e?
The NiMh AA batteries look quite good, I'll show those to my friend.
Ak Flyer
Fly the wings off
I never used rechargable batteries in my DX5e but the regular alkaline AA's last a really long time. Never seemed worth it to do anything else.
colorex
Rotor Riot!
My friend uses rechargeable, he says he has to recharge them every 2-4 hours of use.
UndCon
UndCon
I use a 3S LIPO in my DX7 (2650mAh) but then it also uses a 8cell NIMH as stock...
No worries and I recharge 1 every "cannot remember when I did it last time" so it lasts months
//UndCon
That seems a bit strange. Almost makes me think perhaps the ones he's using might just be junk, too old, or something.
I use some energizer rechargeable batteries in my DX6i and they last multiple weekends.
fred0000
rechargeables wont last nearly as long as regular alkalines.
rechargables are rated 1.2v where as the regular ones are 1.5v for that radio I would honestly just stock up on some decent AA's and keep some on hand at the field.
another thought i've had but i've never done it, for radios that use 4xAA's is to just get a cheap UBEC that operates at 5v and wire that in, then you could use pretty well any battery you want to make fit. (you would have to disconect the battery everytime you were done, the power switch wont shut the BEC off)
colorex
Rotor Riot!
That could be a solution, it would last forever with a single charge, but you'd have to add a switch that cut's the battery power.
colorex
Rotor Riot!
I use the exact same battery for my Tx, but it's also 8cell - NiMH. I haven't charged the battery fully as I'm afraid this would overheat something. Should I worry? I mean, what's the voltage difference between a fully charged 3S LiPo and a fully charged 8S NiMH?
fred0000
I use a fully charged 3s lipo in my 9x, was using old 900mah 20c packs at first but now have a propper 2650mah unit, best thing i've done so far was convert my radio's to lipos, some people only do a storage mode charge to keep the voltage down, or you could get a 3s life pack if your concerned.
UndCon
UndCon
You take a risk using a fully charged LIPO as it exceeds 12Volts.
To avoid this add a couple of diodes to drop the voltage to 11.9 (and sometimes get correct reading)
I only use a 2S in my Turnigy (ER9X)
colorex
Rotor Riot!
My voltmeter has a dead battery, so I can't determine exactly the right voltage. Is 11.9 the maximum NiMH battery voltage limit?
UndCon
UndCon
No but in some radios they do not show proper voltage when using LIPO so you have to drop below 12V for voltage meter to show correct values
There is no guarantee things still work when you use more than 12V so it is a good thing using diodes to protect the radio
//UndCon
colorex
Rotor Riot!
//UndCon
Do you happen to know what diode values one can use to regulate the voltage? Or do I just keep charging until 11.9 - 12 V?
UndCon
UndCon
Colorex - as you can read swedish:
SMFF
Others can look at the images ;)
Diodes used are 1N5400 50V 3A
Solder 2 in parallel to have a backup if 1 should fail.
1 or 2 diodes in series might be needed to drop the voltage on certain radios.
Personally I find it easy to abort the charge at 11.9/12V
//UndCon
Rcjim11
A standard diode can be put in series to drop the voltage by 0.7V. More can be added to acquire the desired voltage drop
colorex
Rotor Riot!
Thanks! That's a very good tutorial!
For those who can't read Swedish, it says "solder the diodes like in the picture"
@Rcjim11 What is considered a "standard" diode?
fred0000
for the cost of it, and how simple it is I may have to get some diodes and do this, in the meantime I will still continue to use the lipo in my radio fully charged since its been fine for the past few months, I would love for the voltage reading to be accurate.
the diodes can be found on eBay for $3.50 for 50 of them i'm going to look localy first as this isn't an urgent issue for me.
(hey Andre, I had a thought about the BEC powered radio, we could take the radio apart and jump the existing power switch so it's on all the time, then use the factory switch to turn the BEC on and off, it would effectivly turn the radio on and off aswell)
