The V-tail motor mounts are available in out web store. As is the single piece landing gear and the tab kit that transforms the Replacement Delrin - Straight 13-370 into a landing gear.
The original V-Tail quad featured in the Bat Bone episode.
The motor mounts were made from aluminium that were drilled and bent to 40°.
It was difficult to get the angles identical.
So we made this 40° V-Tail motor mount kit
Simply glue together
The motors used in this build are the SK3 - 2822 - 1275kV
The motor mounts simply squeeze onto the 1/2" booms
Perfect angles every time.
The Bat Bone frame needs to be modified to accomidate for the dual tail setup.
The Any Copter can also, very easily be made into a V-Tail Quad.
The two tail booms mounted. The frame can still be used as a normal tricopter after the modification.
Front arms in place.
The tab kit transforms the Replacement Delrin - Straight 13-370 into a landing gear.
The Single piece landing gear is really tough and can be used on both 1/2" and 10mm booms.
Electonics mounted.
David shows in the video how to set up the KK2 board.
He also shows how to do the first flight adjustments.
Settings used:
Stick scaling:
- Roll: 45
- Pitch: 45
- Taw: 60
- Throttle:90
- Roll and pitch
- P Gain: 42
- P Limit: 100
- I Gain: 23
- I Limit: 20
- Yaw:
- P Gain: 50
- P Limit: 20
- I Gain: 50
- I Limit: 10
- Channel 3 and 4
- Throttle: 100
- Aileron: 0
- Elevator: -90 / 90
- Rudder: 100 / - 100
- Offset: 0
Gear used:
- Flight controller: KK2
- Motors: Turnigy SK3 2822 - 1275kV
- ESC: Multistar 15A
- Props: Gemfan 8x4.5
