Flight Controller: Velox F411 Lite
Battery: 2000 mAh Li-ion 2S (7.4V)
It looks like this board has a BEC built-in...so do I not need to buy a 4-in-1 ESC and use the harness section/plug-in on the back? Snip off the XT30 connector from the thick battery leads and solder straight to the FC?
Which pads should I expect to use for these respective components?
- Main prop
- Servo 1
- Servo 2
- RunCam
- VTX (connected to 5.8 GHz antenna): TBS Unify Pro32 Nano
- GPS
- 2.4 GHz receiver
- Battery
