I have built a few Versa wings and allways had asked my self a question does reflex on the elevons or does CG cause a twitchy up and down on the elevons? This one glides for ever with out any input with power off but is one of the twitchiest I have built. I will probably experiment with this one but thought I would get others input on what they have found.
The reflex/CG is not the cause of the "Twitchiness". The short distance between the elevons and the balance point is the real reason.
Other things can make it even worse. A lack of Expo, a balance point behind the actual CG point, (tail heavy?), Too much elevon deflection.
Do a stall test and if it wanders from side to side and then drops a wing as it stalls it is definitely too tail heavy!
Change the mix ratio in the Tx from 50:50 to 60::40. (Aileron:Elevator).
A proper setup can make all the difference!
Have fun!
