Versa Wing Electronics Compatible?
summitflyer
Hi all!
I built my versa wing a couple of days ago but needed to make an extended battery tray to balance it out since I will not be putting a camera on it. I am using the ft firewall to which I mounted my turnigy 2200kv (2826)motor. It is using a 3 cell 2200 mah lipo and a turnigy 45 amp speed control. I know the speed control is too big but will this be too quick on a 7x6 prop apc? I have not maidened it yet.
Best Summitflyer
dwardio
Without having the full specs on all the components, it's hard to know for sure, but I think that setup will only pull around 15A. More experienced builders will no doubt give you a better answer.
There are a number of (free) web-based power system calculators available. they can be a little daunting to use, but hang in there and you'll figure them out!
http://2bfly.com/tools/
http://adamone.rchomepage.com/calc_motor.htm
http://www.ecalc.ch/motorcalc.php?ecalc&lang=en
Btw, a "too big" ESC shouldn't cause any problems as long as it matches the number of cells in your batt.
Cheers, D
