I am in the midst of building this bird and have watched the videos but have a question on Rx placement. I elected to put the servos on the top of the wing, am building a pusher so no power pod. Some of the videos I saw showed the battery mounted forward on the top of the wing as the CG is critical and most advised a lot of weight was required in the nose. My real question though, is where do you put the Rx? It looks like some have placed it inside the wing thru the bottom but there are no clear videos of this. That sort of makes sense as the servo leads are within the wing. Has anyone done this and could you share where you made the cuts?
