Versa wing Pusher props
Battery800
So I’m getting a versa wing sometime after the lockdown ends. If it is going to be in a blunt nose configuration, should I get a 10 x 4.5 prop or a ccw one. If so, does anyone know where to get the regular (not slow flier) ones? Any advice is appreciated!
It doesn’t matter which you use. Both a CW or a CCW prop will work equally well. I use quad props on my pusher Versa. Always put the numbers facing forward & make the motor spin which ever way it needs with the prop you have.
Battery800
Also, would power pack c motor work with the 10x4.5 prop?
Battery800
I just don’t want to spend the money getting extra stuff like servos, the y cord, and linkage stoppers. Rather just get motor, esc and props
