Today I got to go out and make a good four flights in really good air and I have to say i'm disappointed with the Versa. With fairly high speed, if you pull hard elevator the thing snaps left into a spin....every time. If you slow down , it wants to tip stall and when it does stall it drops a wing suddenly, you'd better have some room left to get it back. It is the kind of plane that you have to stay on top of every second. I'm not sure what the problem is with the automatic snap spins, I think weight is to blame for the poor low speed handling. Fortunately it only costs 25 dollars, because it isn't going to live long like it is.
Sorry to hear you've got more problems! I haven't experienced any of that with my three builds (one pointy, two blunt nosed) Versa's. Can you post pictures of your build focusing on the control surfaces/elevons, linkages and servos? I wonder if you have too much slop on the control rods? Did you put coffee stirrers taped down to the wing, or some sort of guide similar to ezikiel12 on yours?
My versa all tracked like they were on rails with a TX setup with everything between 100% throws/0 expo to 50% throws/30% expo. I typically like to fly mine with 70%throws/30% expo.
I've had 1-2 tip stalls/snap rolls while coming in for a landing where I lost too much airspeed at too high an altitude, but they were also windy days with shifting wind direction that made it hard to land straight into the wind.
On calm days (generally when I maiden a new build), I try to test out everything, which includes high altitude (3-4 mistakes high) unpowered glides to check the stall characteristics, and generally I can stay up wings level with full up/back elevator. I have to put in some aileron input to make it snap roll/drop a wing, but it recovers quickly.
Everytime I fly my versa, I actually feel ok about chopping the throttle at high altitude, and letting it glide if I need to take my eyes off the plane because of something happening on the field, or needing to look at my TX. I feel it pretty much flies hands-off without any stabilization hardware. I did happen to mount an APM in my latest build, and took it out to tune this past weekend. I was flying lazy 8 patterns for about 20 minutes in the APM autotune mode and took my eyes off momentarily to look at the tablet screen that was running droidplanner to check the roll rates as measured by the APM, and look at my battery voltage. I actually got bored of flying the figure 8's and ended up landing because it was getting hotter and the wind was picking up. Still had 3.9V per cell after 20 minutes of APM tuning where autotune requires you to give max roll inputs 20+ times, and pitch inputs 20+ times.
