I am having trouble with the build of my flite test viggen v2, mostly because the fuselage has a seam in the middle so the foam board can fit in the box. Does anyone know how I should build it with this seam?
I've never built from the Viggen SBK, but usually the seams added into the parts for packaging ease need to be glued.
The only Viggen packaging seam I know of is in the wing, see build vid, but things change.
Maybe the Viggen V2 Build video will help:
I have the v1 and v2 kits. The seam really wasn't an issue. it goes down the middle of the wing, but you just use hot glue and unfold it flat, then scrape the excess glue off the seam.
