Vimana89
overhauling to add pics and info of proptotype2/1.0.(the proper release model on the plans) a lot of current info here on page one is only about the first prototype, which had flaws in the air flow that lead to stalls
Prototype 1
I threw this together last night and this morning, for several reasons. I had some parts from a failed build around an radial 1806, and was getting burnt out/needing a break from super slender deltas, FTFC20 entries, and any kind of RET plane. I need to push forward with my aileron Kung Fu. I wanted something more along the lines of a more standard delta or fighter, that would be Nutball level easy to build, and extremely easy and forgiving to fly. This is about mighty mini size, with a 20" wing span by 24" wing chord and 30" or so overall length. After a rough maiden with a heavy battery and not ideal prop, I tried with 850 3s with 6x3x2 prop(a very standard setup for this size plane) and she flew outstanding! Not particularly aerobatic, but super smooth turns, awesome stability, and full stability, turn, and climb at low speed on half throttle. I'll get some video when I can get a new cheap action cam, which will be soon. This plane looks a bit crude now, but flies great, and can always be made neater in later versions.
UPDATE: flies just about as well with 850 5x3x3 as with 6x3x2, though the quality of the three blade props is flimsy. I added a small horizontal stabilizer or "Taillet", and got more used to flying ailerons. This plane not only handles well now, she handles exceptionally nice. The speed envelope is quite flexible, and with a little practice, this plane can easily be flown very slow or quite fast. This is no high alpha stunt plane, it won't do a big cobra or tail stand, but is capable of a little gentle high alpha for low and slow flying, and high alpha flares for landing. I will try to push the high alpha a bit more and see how much she can do, but it won't be anything extreme. For basic yanking and banking and smooth turns, I have not built or flown a better plane yet.
Prototype 1
