VISTA v2 - a slippery pitcheron
bracesport
@Wildthing - is the CF and epoxy thin? Yes, it is about 0.5mm - the former is a 3D printed 0.8mm wall fuse - three or four sections, no internal structure - once I cut into the canopy area I will be able to show you the cross section.
bracesport
I am pretty impressed after doing the sausage wrap for the first time - canopy step is good - surface needs a little tickle up but it is not half bad - dry fitted the tail and it is starting to look like a glider!
bracesport
Some wing progress too - I used a wire guide to cut the SWS spar shape through the wing - I have tape on one side of each CF strip and there are two CF strips glued into each wing - the tape is between the strips so I could epoxy the CF to each wing half and the tape allows the CF strips to slide against each other while bringing the halves together - once dry I will separate the wing halves, remove the tape and epoxy them together permanently.
Boberticus
So Awesome. its insane how narrow those strips are, just enough weave to hold themselves together. did you go through any extra steps to get them cut that narrow or just some spray adhesive, scissors, and patience?
thats not prepreg right? you just wetted them out and have something sandwiched in for release? you gonna just mark it in place and remove and carve out the final spar? have any plans to make a mold for duplicates before installation?
This is such a weirdly cool and intricate build. lots of different skills necessary to pull something like this off.
bracesport
@Boberticus - this CF weave is not pre-preg so I either spray glue it to a surface on in this case I stuck tape to one side to hold it together while cutting the strips - epoxy went on the foam side - CF strips were pressed onto the epoxy and the tape ended up back to back in the middle - next I will separate the wing halves again, remove the tape (and trim the excess), then epoxy down the middle of the spar.
Wildthing
]@Boberticus - this CF weave is not pre-preg so I either spray glue it to a surface on in this case I stuck tape to one side to hold it together while cutting the strips - epoxy went on the foam side - CF strips were pressed onto the epoxy and the tape ended up back to back in the middle - next I will separate the wing halves again, remove the tape (and trim the excess), then epoxy down the middle of the spar.
Cool procedure
bracesport
The strips of CF adhered to the wing halves and with their backing tape removed I could easily epoxy the spar together - I will still need a little trimming on the top surface after glueing - I am also printing some end caps for the wings to help with aligning the wing tubes and rotor pins. :)
bracesport
Here are the wing tubes with magnets glueing into the stub ends - in principle the magnets will hold the wings onto the fuse/wing-rods - I have also glued the rotor pins into the wing cap ends and to assure their alignment they are glued across both end caps. :)
Wildthing
bracesport
This morning I cleared out the channels to epoxy in the wing tubes - the channel is deeper at the far end of the tube to create a small about of dihedral so the wings do not look drooped - I tacked in the wing tubes with 5min epoxy and checked they are about 10mm up at the tips when the wing rod is parallel to the bench - after that, I filled the void with epoxy and micro balloons.
Fingers crossed! :)
