Wildthing
It definitely is. That should be one sleek bird.@Wildthing - I don't want to jinx it, but it is coming along quite well at the moment!
Totally awesome. How does the wing feel for strength ?Sanded the excess CF spar material off - cut the tip shape and thinned the top side of the tips - my plan is to bag the top side first then complete the underside sanding and bag to finish the wing - filled a few voids at the root and tip - this way is a bit slower but gives me the flat underside to bag the top surface against.
View attachment 173749 View attachment 173750 View attachment 173751 View attachment 173752
What are you going to do for sheeting?@Wildthing - actually, the wing is still quite flexible - it should stiffen up when the wings are sheeted and they key into the spar (as well).
Super slick wingsIn this instance my goal is to sample my design - play with CF (Skins) and fuse - push myself - I have watch a lot of YT and my first attempt is a simple approach - I hand glassed a previous wing and it flies well with no spar, so I am sure this one will be better and stronger, and a Pitcheron of course!
Laid up the top skins with about 15g of epoxy each - popped then in the foil sleeves (no mylar) to keep things clean - the CF tow fabric @0.8K is light but a bugger to wet out - now we wait!
View attachment 173938 View attachment 173939 View attachment 173940 View attachment 173941 View attachment 173942 View attachment 173943 View attachment 173944 View attachment 173945 View attachment 173946
That looks really slick, I don't think you should paint it.Well I am pretty impressed with the first attempt - the foil sleeve was to slip the wet wing into before putting the wings into the Vac bag (think of it as a thin mylar just not as stiff)!
my foil in theory is a modified MH32 10%
View attachment 173999 View attachment 174000 View attachment 174001 View attachment 174002
