Matthewdupreez
Ok.. so the prop must be flush against the motor, and the nut must be tight enough that when you hold the motor and try to rotate the prop it doesn't slipUsing a Power Pack F.......
Not a good idea... As it can mean that it breaks every time you do a hard landing...Hmmmmm.........That makes doing cowlings a bit difficult, but I think I know a way. We make a plastic extension of the prop shaft (complete with 9 cylinders!) Slide the extension through the cowling & bolt the prop onto it.
Forgive the crude drawing.....We can make them with 7 cylinders, 9 cylinders, Oberursel or Clerget or any other rotary.
just plastic to hold the prop isnt a good solution at all , as @Matthewdupreez says, move el. motor forward.
Always mount prop on el.motoraxle/prop mount on el.motor axle.
Rather move the motor forward..
Ah skins! What fun! I guess it depends on what you mean by the word "Skins". For clarification, are we talking about digital images created to be wrapped around a digital frame for use in computer games and simulations? Or Digital graphics created to be printed at hi-resolution on foam or paper for foam board RC planes? I ask because the above look to be wonderful examples of digital images created to be wrapped around a digital frame.
Well. I for one don't watch any of your videos, due to the fact that I stay away from strong language.Ok, I'm gonna hafta ask the mods to step in. Y'all are posting WAY TOO MUCH in my thread.......
A stranger walks in with 20+ years in the Flight Sim Community & an amateur historian of 30+ years. He proceeds to build not one, not 2, but 3 WW1 aircraft, all in historically accurate livery.....
AND NO ONE BATS AN EYE??!!
Happens all the time, does it?
Oh, and I totally forgot to set my expo & throws in my transmitter. No wonder it was acting like a bucking bronco!
.....I'll fix it & try again!
Your builds look great . But honestly I don't have time to comment on every single post
Many people on here are under 18...My bad, I didn't know you were a minor. There I go assuming again........My fault.
