BATTLEAXE
I am doing the Bloody Baron right now, and it has just the one balance point and with the power pod in with the motor and prop installed but no servos It sits nose heavy to the point where it just wants to fall off my fingers. The battery in the pod sits back of the CG, probably 4-5 inches from the firewall to balance the plane as is. Servo placement will help nudge it forward some but not much.I am starting at 55mm back from the LE which is very close to the rear mark and almost the same as the Baron, the front mark seems just to far ahead .
I am thinking that if there was two CG marks the second set would be a 1/2" forward of the marked ones to make it more nose heavy to balance for a more aggressive penetration in the air, Is that correct?
