Solved Vtx wont turn on
Tom26
I wired up my new fpv gear for the first time and when i plug the battery in it dose nothing and the lights on the vtx are not running.
Im running
A runcam swift cammera
A succex force vtx
A TrueRc blaze led antennas
Bifi.baarlo
Im running
A succex force vtx
It only needs ground and power 7-34 Volt, if that is right, than it is broken, maybe you powered it up without antenna?
Did you do a complete setup including adding the vtx tables? It it set to only power on when armed? Is it set to pit mode?
this video gives a basic set up run thru that may help you.
Tom26
Would powering it up with the antenna in but without wiring up the antennas led break iti
It is for a plane so i am only using the vidio + and two - pins
Bifi.baarlo
Like I said, it needs power and ground to turn on, that's why it isn't doing anything.
Tom26
The vtx had power and ground but i was meaning the led in the antenna but i think it is separate.
