If it rolls to the left, put it on the left (driver) side. If it rolls right then right. If it climbs during throttle, put it on the top to give it down angle. I always mount my motor mounts in the ⚔️ pattern, but I print all my mounts out, and I think the FT wood mounts are ➕. With that said it should still work fine. Just start with one and take a few to the field with you to find the sweet spot.
If your firewalls are wood, Over time the washers can bite into the soft wood and flatten out you thrust angle again. Not a big deal at all, but if you fix the thrust angle and after many flights the torque roll returns, that may be the reason. Should not happen quickly, but if your plane last long enough, it might.
