Water Resistant Flite Test Foam is available on the store as of 3/22/16
https://store.flitetest.com/flite-test-water-resistant-foam-board-by-adams-50-pck/
I'm starting this forum thread in the hopes that we can all capture and share everything anyone needs or wants to know about the new water resistant Flite Test foam. I was fortunate enough to get a box to start doing some building and testing with. I will share my thoughts and opinions about it here. I'll Add information to the first post as time goes on.
Currently available kits in water resistant foam board include:
- Cost: $100.00/case of 50, or $2.00/sheet
- Yes, it's brown
- It weighs the same or slightly less than the white Flite Test Foam
- It is the same thickness - 3/16" (.1875)
- Sheet size is 20" x 30" (508 mm x 762 mm)
- It's Paintable (scuff with 220/400 grit sandpaper for better paint adhesion)
- You can still easily peel the paper off to bend the foam.
- Bloody Baron
- Bloody Wonder
- Bushwacker
- Explorer
- Guinea Pig
- Mighty Mini Arrow
- Mighty Mini F-22 Raptor
- Mighty Mini Pun Jet
- Mighty Mini Tiny Trainer
- Mighty Mini Vector
- Otter
