T-Richard
Long Story short, Video transmitters do not like water, they also do not like corrosion X. Liquid tape either... Cameras are equaly fragile.
This is my dead gear and the result of an expensive and unsuccesful experiment.
I fly a lot over water and snow and I wanted to protect my gear. Here is a nice raw flight
One day the landing may go wrong, and some have in the past. The results are usually a dead VTX/ camera which gets expensive.
While the tricks for the flite test vide here do work for basic electronics, FPV gear will need a better approach
The tests
I tried liquid tape, Esseentially it worked for one board cam but not for the other. A 50% success rate is not good enough
Hot glue doesn't stick so well to wires so using that to seal doesnt work well for either esc or VTX. may work for flying in rain but submersion in water or snow will not work
I used Corrosion X on 2 Vtx and they are both dead, they transmit a signal but no video or sound. ie no static on that channel but nothing usable either.
I did spray some corrosion x inside an 808 and that works ok but haven't fully submerged it and would rather let that happen "naturally" so I'll report back when I crash in the lake
The moral of the story DO NOT ATTEMPT THESE TECHNIQUES!
what can you do?What DOES work?
Here is a technique that did work
http://www.lowes.com/pd_51220-72643-LW284___?productId=3102449&pl=1&Ntt=silicone+clear
I buy a knock off of this for cheap. I use it to seal ESCs instead of epoxy like in the flitetest video, it's lighter and more flexible which is useful. I use it to seal cameras that are enclosed like this http://www.hobbyking.com/hobbyking/store/__80831__FatShark_700TVL_CMOS_FPV_Camera_NTSC_PAL. html
I put a bit on all the seams and where the wires exit and under the head of the bolts. Seems to work so far.
For the Vtx, I treat it like an ESC and put long heat shrink and then once it's wired, has the antennae installed and you selected the right channel I seal the opennings with the same stuff. you can always cut open the heat shrink and remove the silicone later if you have to. It's not easy if you used the above epoxy tehnique.
Project Ressurection
I decided to blow off the corrosion X off the gear and put them on a rice bean bag in a ziploc in the sun a few days to try to dry them off. I plan to empty another air can on them and see if I can bring any of these 4vtx and 1 board camera back to life.
I'll report back.
May you learn form my mistakes
The tests
I'll report back.
