What antenna for my goggles when flying Inductrix FPV + ?
I am just getting into FPV and I have a question. I bought the FatShark Transformer goggles and a Inductrix FPV+.
The goggles don't come with an antenna. I can't find any specs on what type of goggle antenna to use with the Inductrix.
I would appreciate being pointed in the right direction.
Thanks
Bricks
Being the Inductris is so small that more then likely you will be more proximity flying I would buy antennas that you would like to use on other projects, Inductrix comes with a dipole antenna and I use right hand spiral antennas and it works fine.
rockyboy
Skill Collector
With my Inductrix I use a 5.8 ghz dipole, linear, or patch antenna that is not a circular polarized (the Inductrix antenna is dipole) - with an SMA connector (very important for your goggles!). With a circular polarized antenna (right or left doesn't matter) you'll be OK-ish as long as you stay sort of close range.
For some good background reading, check out
https://oscarliang.com/linear-circular-polarized-antenna-fpv/
According to places like GetFPV
the transformer should come with a pair of dipole antennas in the box already.
Some examples of these antennas are:
https://www.getfpv.com/fpv/antennas/fcmodel-5-8-tx-rx-racing-antenna.html
http://pirofliprc.com/Pyro-Drone-5G8-Linear-Antenna-With-SMA-Connector-6-cm-_p_3716.html
https://www.banggood.com/5_8G-3dBi-...CN88QAvD_BwE&ID=513344512670&cur_warehouse=CN
This one is going to be pretty directional - i.e. if you turn your head you're going to really effect the signal.
https://www.getfpv.com/fpv/antennas/aomway-biquad-sma-5-8ghz-dual-diamond-directional-antenna.html
