what is the slowest plane on FT
sundown57
ok, here we go. I finally got the plans printed out and cut. First thing I noticed if there is no dihedral gauge, and no step by step build video. In fact, there is not much at all on how he ran the servo pushrods, where CG is. so looks like it's going to take a bit of trial and error.
sundown57
yes but no gauge in the plans to set it at. I guess ill go by the angle on the tips and make one my self so i can get both sides the same
sundown57
Some times you just get lucky. Its 2 feet from cg to the tail and i wasn't sure how to run rods that long without tons of braces, and the tail is so very thin I didn't want to cut a slit in it cause there just wouldn't be anything left to hold it together, Then I remembered I had a couple of long cables with sheaths, Sure enough, they are just 24 inches. Ran them on top of the tail section, 2 spots of glue an done. The fit perfect and work great.
bracesport
@sundown57 - great job, you make your own luck! - yes, the tail is a tad thin - if you want you could glue a BB skewer to each side of the tail section of the fuse for extra strengthening.
sundown57
yeah, I thought of that. But I've tried really hard to keep it super light. so thought id try it this way first and see what it does.
sundown57
Something I need to explain. I have been doing this hobby now for about 6 months and built quite a few planes during that time . most all looked great but I never really got the chance to fly any of them, Mostly due to lack of experience. Also not having any really big area to fly in didn't help. Well, anyway I was just about to give this whole thing up because I had really lost interest in building planes I knew I couldn't fly and this thread was a last-ditch effort. Well long story short, today was a perfect day for flying. No wind, nice and warm and heavy black clouds to block looking straight into the sun. So I took out the last 2 planes I had to do a maiden flight on both one day. End result is I came home with 2 planes still in tack and 2 dead batteries. It was AMAZING. not only did I regain the drive to keep chugging along. I have a renewed interest in both building and flying. So wanted to say THANK you to all that chimed in and all the help and support I have found here. If ever anyone else reads this and is thinking of giving up, DONT. I'm proof that with the support people on here it can be done. Ok, enough tear-jerking. here are just 2 of today's flights, now I'm on to build another plane. thanks all.
The first video is the fish, Second is the second Biplane I built.
#49
Never give up on this! It's all about trial and error, and learning from it!
#50
Congratulations!! I'm sure after a few more flights you'll find yourself wanting to fly all the time.
sundown57
im using the flysky I6X and yes that was very much my problem I was always setting it at rate 70 and expo 30. the other night I glued a push rod to a servo arm and glued the servo to a piece of foam board and sat and watched what it was actually doing. I had it reversed. Plus it helped me a lot to understand rates and expos. Now I set the rate at whatever the plane calls for and set the expo up around 60-70. that helped a LOT.
