My wiring is defiantly fine, everything on the plane is functional. It just randomly did this suddenly and I don’t know why.
Well… that’s the sound that an ESC makes when it isn’t getting a PWM signal from the receiver. 🤷♂️ Wiring broken, bad receiver, bad receiver settings maybe (set to PPM/SBus output instead of PWM), plugged into the wrong port, maybe set your receiver to TAER vs AETR
If you have a servo tester, you could connect that to the ESC instead of the receiver. If that works, then it’s something wrong with the receiver or the connection to the receiver.
