What kind of battery will be compatible with this motor and ESC?
enola_yay
Hi everyone,
I am currently building a full-sized Guinea Pig and need some advice on batteries. I have the following motor and ESC:
Emax GT2215 1100kv motor
BLHeli Series 30A ESC (XT60)
I am really unfamiliar with batteries and their compatibility with the ESC and motors. Can someone guide me here? Not sure where to start, except that it should be a 3 cell battery, right?
Thanks! :)
dayve
Flite Test recommends an "1800 - 5000 mAH 3S" battery for the Guinea Pig.
On my bigger planes (a FT Sea Duck and an Ansley Peace Drone), I like to run dual 2200mAH 3S batteries. A parallel connector is pretty easy to make for yourself. It's only a couple bucks for a pre-made connector if you don't feel like messing with it or don't have spare XT60 connectors laying around. When the packs are connected together, they just act as a single 4400mAH 3S battery for both flying and charging purposes.
This gives me the option to use the packs separately in other mid-size aircraft, or together in the bigger aircraft. You could also opt to just run a single battery if you wanted the extra payload capacity for dropping candy or something out of the Guinea Pig. Just keep your center of gravity (CG) in mind if/when you fly with a different number of batteries. Either the battery tray needs to be right on the CG, or you need to adjust the pack(s) forward/backward depending on how many you're using.
Not to make this too complicated, but I'll also mention that if you choose to run a single pack at the lower end of the suggested range, you'd need to keep the C rating in mind. The low cost batteries I typically run are rated for 25C. Depending on the brand, that rating can be a bit "optimistic", too. An 1800mAH 25C pack is only rated for about 45 amps. That pack may not be real happy about flying a decent sized twin-engine plane like a Guinea Pig or Sea Duck. Once you get up into the bigger sizes (or parallel connected smaller packs), you can get away with running the cheap 25C packs.
Chappie66
I am also in the same boat trying to figure out what battery(s) to buy.
From what I have read and am slowly understanding, the 2 x Emax GT2215 1100kv motors can draw upwards of 24-26 Amps full load on a 10x4.7 prop. That would be a combined draw of 50+ Amps. I presume this would be a temp surge state as the demand is asked for and then level out?
If that is correct I would look for a battery pack that is capable of handling 50C bursts with somewhere around 25-35C, or higher as required,constant discharge.
If anyone has experience with this sort of problem, please chime in. :)
PS. Sorry for hijacking the thread.
quorneng
Chappie66
You are confusing amps (A) with c rating.
The amps capability of a battery is determined by its capacity (in mAh) and it c rating.
So for example a 2200 mAh 20c battery is capable of providing 2.2 x 20 = 44A. However it would only be able to do this continuously for 1/20 of an hour or 3 minutes. Obviously a 40c version of the same battery could provide 88A but only for 90 seconds but be aware that discharging batteries at their maximum design rate for any length of time is likely to significantly shorten their life.
Finally remember just using a bigger battery is not the complete answer as it adds weight which needs more power to fly so it follows the law of diminishing returns. Also at some point the plane will become heavy and difficult to fly.
My 'rule of thumb' is to try to arrange that 'normal' flight discharges the battery at about 10 c (22 A for a 2200 mAh battery) and use the maximum rate discharge for only a few seconds usually take off or for a particular aerobatic manoeuvre. A 10c average rate of discharge will give a flight time approaching 6 minutes.
The lower discharge rate you can achieve the longer the flight time but it requires careful design to do.
enola_yay
Hmmmm... still unsure about what battery would suffice for my needs.
I made a harness for my two motors/ESCs that connect together so that you can just use one battery. So would a single ~4400 mAH 3s be sufficient for my esc/Motor set-up? What C rating should I look for?
https://hobbyking.com/en_us/zippy-compact-4500mah-3s-40c-lipo-pack.html?___store=en_us
https://hobbyking.com/en_us/turnigy-4500mah-3s-30c-lipo-pack-xt-90.html?___store=en_us
https://hobbyking.com/en_us/turnigy-nano-tech-4500mah-3s-35-70c-lipo-pack-xt-60.html?___store=en_us
Here's a few batteries I found in that range. Any of those look like they would work for me?
Sorry guys -- I will admit I am very lost when it comes to this stuff. I have a lot to learn :-(
