what motor should I get?
I have run out of motors after using up my DT-750s on my tricopter.
My previous purchase of Turnigy Aerodrive SK3 - 2822-1090kv Brushless Outrunner Motor turned out to be a bummer. They are burning up with Plush 30 amp escs with 8045R props.
So, now the question is.. which motors should I get?
The options currently are:
DT-750
NTM Prop Drive Series 28-26A 1200kv
NTM Prop Drive Series 28-36A 1200kv
Any other suggestions are also appreciated.
xuzme720
Dedicated foam bender
I'd go with the NTM's. I've had good luck with those after oiling the bearings before flying them...
is NTM 28-36A 1200kv a good choice?
Why do you have to oil the bearings before you fly?
Should I be oiling DT750 bearings too?
(oops update: now I read that as oil bearings once you get the motors)
