What size banana connectors?
Flying Monkey fab
Hey, a quick search came up null so I will ask. I need to order some banana/bullet connectors but I see they come in several different sizes, does anyone know what size FT uses on their power packs?
Thanx
FDS
They are usually sized according to the current draw, so a bigger motor will have bigger plugs.
My F pack had 2mm plugs on. If you don’t have the right size it’s not hard to just solder the connections, if you do that be sure to insulate all 3 before you apply any power.
Flying Monkey fab
That makes sense, do you know what size they use on the c pack?
FDS
All my larger motors were supplied without connectors or 3mm ones, depending on where they are from. We can’t get power packs here in the UK for sensible prices. You could just ask FT customer service.
