Hi everyone,
I am new to RC flight, and I want to get into FPV planes. But as a newbie to the field it is quite hard for me to get a complete picture of all the available technology.
I live in the Netherlands where we have rather strict rules about frequency use; in essence we are allowed to use 35MHz, 2.4GHz and 5.4GHz (amongst others) without a radio license.
Since 5.4GHz is not very powerful when transmitting through obstacles, I figured I'd want to use 2.4GHz for video, leaving 35MHz for controlling the model.
As a (pre)beginner, I don't have any hardware at all, and I want to avoid buying a lot of expensive equipment that I'll be replacing down the road. That's why I was thinking of starting out with a simple plane (HK Bixler 2) that I can keep adding stuff to, and a decent radio.
I understand that there are different nested (sub)categories of 35MHz communication:
Assuming this breakdown is correct, you'd simply have to follow the path through this nested structure along the nodes marked better, and you'd come up with the following requirements that a fictitious BEST Rx/Tx combination must satisfy:
Now my questions are
Is this information correct and complete?
Does such a Rx/Tx combination exist?
- channel configuration using chrystals
- synthesized radio (non-chrystal tuning) better
- PPM (analog data transmission)
- PCM (digital data transmission) better
- one-way communication
- DSM (Digital Spectrum Modulation) two-way communication (plane talks back) better
- FHSS (Frequency Hopping Spread Spectrum)
- DSSS (Direct Sequence Spread Spectrum) better
- synthesized
- PCM
- DSM
- DSSS
