Thanks for replying, im looking at doing FPV at a range of 2 to 5 miles , been looking at a 2.4ghz setup with a 1000mw transmitter , but it looks like what i have read a 2.4ghz Fpv setup womt work with a 2.4ghz rc , what is your opinion on this???
The best gear that you can get is:
EZuhf with an srh-711 transmitter antenna and sander style antennas for your rx. From readymaderc.com
2.4 GHz 500mW lawmate video transmitter team-blacksheep.com
8 dbi or 12 dbi patch for 2.4 GHz fpv. Higher dbi is a narrower beam in which in the antenna can receive data.
With this setup you can fly with easily 10 miles.
Reason why you should not go for 2.3 GHz imho
Antenna size will be only smaller by 0.5 cm or so. No big difference
Yes you are away from wifi and stuff but thats not a really big problem so it wont matter that much, maybe when you are going for 20+ km. Also when you use the higher channels on your transmitter you will also be away from the wifi and stuff. Wifi is 2400mhz
Lawmate is proven quality by allot of people in different situations.
2.4 GHz rc wont work with 1.2/1.3 GHz or 2.4 GHz fpv.
DONT buy the lawmate 1000mW transmitter series its crap, old tech bad filtering
