Wheels for Power Pod
darryn
Hi All,
In the video on the build of the power pod, I see that there where some nice store bought wheels used, in addition to the ones made of foamboard. Does someone have the details/size of the store bought wheels?
TIA.
mymaps
Always trying to keep they as light as possible (i.e. dont use rc cars wheels) I guess you can use any like these ones from Hobbyking
Different is how to attach them .. still looking for some stiff wire that doesnt bend on every landing :)
Edit: a couple bags of the yellow ones are on their way home, I'll upload a few pics when they arrive ;)
munchie
These work great for me
I found that a nice cheep alternative was to use 'Pinewood Derby" wheels from the BSA. They were like $3 for a set of four from my local hobby store. I've been using wire from "Home Depot" that is used for hanging suspended ceiling tracks. It's the perfect weight and can be easily readjusted. Buy one bundle and you're set for a very long time. I attach the wheels to the landing gear using servo clips. They work like a champ!
ViperTech
If you have access to it, pool noodles make great wheels, with plastic bottle caps for the rims!
I use 3/32" piano wire for the gear, it does bend on hard landing but you just bend it right back!
I found #4 nuts just fit the wire snuggly and with some C/A they stay put!
View attachment 30660 View attachment 30659
Winglet
FT Wheels
ft wheels.jpg I actually really like Josh's FT wheels. I cut them out myself from scrap using a circle cutter I purchased at Michael's. Glue a little washer on either side of the coffee stirrer or they will wear out fast. They even handle reasonably tall grass well.
Just ordered 40 wheels from hobby king. The yellow ones for light weight use (https://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=65720) and Some somewhat thicker wheels when the weight isn't an issue. My Flying Venues are limited to a rough ballfield or a dry lakebed so my landing surfaces are far from smooth. That said the 40mm is about as small as I want to go and I hope to pick up a few larger diameter wheels in the future. At less then 2$ for 10 you cannot beat the price.
As for the wire bending there are solutions available depending on the effort you wish to invest. Simple solution is to wind a line up the wire for about an inch, CA it into place then stretch over to an equivalent location on the other side. I usually do this about 1/3 of the way down from the fuselage mounting. This leaves some bend still in the wire for rough landings but keeps it from becoming severe. What another friend did though was to wrap the line on each leg and tie it to a light weight but stiff spring at about the half way mark of the landing gear wire. This worked great for him. All that said I find it much better to need to straighten the wire than for a rough landing to take it's force out on the aircraft.
While I am new here I have been flying for 10 years now and so far I've found nothing more forgiving than the wired landing gear. Stiffer flat bar gear like that found on balsa ARF's tend to have more serious damage than the planes with a wire that occasionally bends on me.
Just ordered 40 wheels from hobby king. The yellow ones for light weight use (https://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=65720) and Some somewhat thicker wheels when the weight isn't an issue (https://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=65719). My Flying Venues are limited to a rough ballfield or a dry lakebed so my landing surfaces are far from smooth. That said the 40mm is about as small as I want to go and I hope to pick up a few larger diameter wheels in the future. At less then 2$ for 10 you cannot beat the price.
bgfireguy92
Good evening everyone. Was getting ready to post an almost identical thread when I saw this. So to expand on the original post I just finished my first scratch built plane and went with the flyer. I bought .055 wire to use for the landining gear and it just doesnt seem siff enough. I see the wires flex and Im REALLY worried about the wheels getting into the arc of the prop and breaking it. So any recommendations for that? And also when I have it on the road or parking lot to taxi and especially when taking off the landing gear seems to lean and cause the plane to almost spin out on the ground. VERY FRUSTRATING!!!!! Any ideas on just making a much better setup?
And MyDigitalParadise would you mind post some pics on your fixes so I can see if that would work for me?
Thanks everyone and darryn I apologize not trying to steal your thread
Winglet
My landing gear mod that works
I've got you covered. Here is a photo of my solution. I use it on all of my power pods and it is rock solid. Instead of making the V bend in the middle of the gear, make it more square so that it straddles each side of the pod and rest on the bbq skewers. (I removed one rubber band for clarity) The pencil points to the gear resting on the skewer.
I purchase my wire at ACE Hardware Stores. It is K&S Brand. .078 order number 505. I think you can also buy it from K&S online?
Happy landings!
Mike
landing gear
HK 70 mm wheels work well and K&S number 506 what we used to call music wire at slightly bigger than 2mm works well but will require a small vice to bend. wire is on line or at lhs. I find that 505 is a bit too weak and gives the impression that the plane is walking over the very shortest grass.
Winglet
Hmmm. Didn't know there was a 506. Slightly heavier would be good. I will start looking for that size.
I'll see if I can find any pictures. My current hanger is set for grass fields so most are configured as belly landers but I know I have some pictures somewhere.
Happy landings!
Mike
Thanks for the picture of your landing gear design ,looks easy and clean. Even adaptable to old builds.
