Help! When I run dual ESC should I run 2 batteries or 1
tuckerlm
Thank you I will try to change the mounting for my edfs such that they have less ducting and move them to be positioned outside the fuselage. Thank you for all the help!
L Edge
Having built and flown a YC-14 with a T tail, I would like to make you aware of some problems.
1) You have quite a large fuse that can block flow to you elevator when you are in a high attack angle of attack plus probably the exit flow of the 2 exhaust nozzles which can cause fluttering at low speeds. So your tail needs strengthening(are you moving the whole t-tail or only part for enough control?) for stability. I ended up moving the whole surface.
2) In your design of exhaust tubes, if the tube flow comes out slanted, it could cause a pitch up problem if not addressed.(did flying experiments to demonstrate effects for my NYGAD design)
3) Are you sure the weight is going to be around 6 lbs? You are going to have high G loadings, so the fuse and wings and tail need good strength which means more weight.
What EDF planes have you tried?
Since this is a first attempt using ducted fans, might I suggest a profile design with everything hanging out in the wind, so to speak? Much easier to tweak stuff until it works as desired 5 times easier to replace crash damage. When it's flying well and comes home with only a new layer of dust, then go all out on whatever fairing, fuselage feature makes you happy.
If you ain't crashing, you're in the center of the flight envelope
tuckerlm
I haven't done any EDFs before. and I plan on 3d printing the plane with a internal support structure and added spars to handle the g load. The 6lbs is a very rough estimate and not all inclusive so it will probably weigh more than that when completed. adjust the T tail to use the entire surface for control
tuckerlm
This is my most recent model.
quorneng
tuckerlm
Are sure you can counter the weight of two 70mm EDFs right at the back like that. The EDFs alone could weigh nearly 1 ib.
The normal rule for airframe design is to keep the rear end light with as much of the weight as possible concentrated around the Centre of Gravity.
I know they are many full size designs with turbo jets at the rear but for the power produced a jet engine is much lighter than an equivalent power electric motor.
If you set the wing at the top of a bulky fuselage there could be enough room to mount the EDF nacelles under each wing.
Quite a popular full size layout for transport aircraft. ;)
RC aircraft design is a complex process so there is no "perfect" solution. Ultimately it comes down to "try it and see".
Keep going!
tuckerlm
Makes sense. Thank you so much for the help and feedback. I will work on mounting the edfs under the wing near the fuselage and then run a test with a small-scale glider model and see how it flies then i'll revise it until I think it can handle the edfs.
