I already learned the hard way that you can't stick a park 480 on an FT Nutball...but...what about when the motors have the same dimensions and weight? The only reason I could come up with is because if you are going to fly a small prop and low speeds, (i.e. you don't need the power) you're probably missing the efficiency curve...but the up-side seems to outweigh that because when you need the extra power or you're ready to put that bigger prop on there or switch to a bigger airplane, you already have your equipment.
All that said, please help me understand which motor you think I should get. I am building several of the swappables and have been using the 2208/14 and it's working just fine. It may be a little underpowered for an 8x6 prop, but not quite sure. I accidentally bent a shaft and am needing to replace a motor...now that I've learned a little more about motors, props and power...I'm wondering why I wouldn't just go with a more powerful motor like this one...exact same footprint...just higher output (watts).
I like to fly slow at first with an 8x4.5 for a bit but then I think I would like to go to an 9x5 or even maybe a 9x6 (prob too big) to get the higher airspeeds. So do you agree that the stronger motor is right for me in this case?
Thanks for your help
