Help! Where should the CG be at?
CarolineTyler
There are online CofG calculators to estimate it. One this I should say is that your vertical stabilisers will not work well as they are almost certainly mostly in front of the CofG and will actually make it unstable in yaw.
#3
I found a calculator but it could only do delta wings so not with the thing in the middle can I just use that one or is that not possible?
CarolineTyler
QUOTE="Fluqok, post: 497724, member: 29128"]I found a calculator but it could only do delta wings so not with the thing in the middle can I just use that one or is that not possible?[/QUOTE]
As it's not swept back you can pretty much ignore it and still be on the ball park.
