I know this is breaking a cardinal rule but I just wanted to test the motors. Since the Gremlin uses a bottom mounted battery it gives me something to hold on to after arming. That being said, while holding the battery, after I arm and raise the throttle, the motors continue to run at max throttle even after I lower the stick back to idle. When I arm, they idle normally. It's not until after I start throttling up that they behave this way.
Is this a normal behavior of a quad that is restrained? I know with the props off, this is normal. The last time I flew it was back in December and I had a crash that broke some props. I just now got back around to flying it and it flew fine before. However, I don't know what's going to happen if I set it down and raise the throttle.
I've flashed everything again and have gone through all the supported protocols for the 6A Emax Bullet ESCs. Nothing changes.
Thanks.
Thanks.
