which one should I choose tri or quad?
hello,
I am planning to make a multi-rotor but I don't know which way I should go. Should I go for the tricopter from rcexplorer or should I built a quadcopter. My goal is to make some aerial photo's/videos with an gopro hero 2.
Here I make a list of the pros and cons of both maybe you guys can add some to them, correct me if I am wrong and give me other advise but anyway here I go.
Tricopter pros:
+cheaper to built because it uses only 3 motors instead of 4.
+no props in front of your gopro.
+less vibration because it only has 3 motors/props. (don't know it's true but I think so)
+more flight time because it has less motors.
+loads of information about it here and on rcexplorer.se.
Tricopter cons:
-don't fly as stable as a quad because it has less motors.
-harder to fly than an quad copter. (read that somewhere don't know it's true)
-can carry less weight than a quad because it has less motors so you probably can't put an heavy camera on in so you have to stick to the gopro.
Quadcopter pros:
+it fly more stable than a tri.
+can carry more weight so it can also carry an heavier battery.
+easier to fly.
Quadcopter cons:
-there probably is going to be a prop in front of your gopro.
-It's more expensive to build.
-Can't find that much info about it. (but I think I have to look a little better)
-harder to get rid of the vibrations because it has more motors.
I would really appreciate it if you guys would/could give me some advise.
Thanks,
Job
hello,
Tricopter pros:
Tricopter cons:
Quadcopter pros:
+easier to fly.
Quadcopter cons:
Thanks,
Job
