Will a 6x3.5 motor with a 3s 850mah lipo battery burn out this motor
skymaster
That is actually the same as a F pack motor. i have one of those on my mini vector . i run it with a 6x4 and a 3s 850mAh or a 1000mAh 3s i use the 1000mAh 3s on windy days. so you are ok
Paracodespoder
F-pack is a 2205, the motor shown by OP is an 1806, which is a-pack 👍.
skymaster
It also depends on what aircraft you are planning to put it on, and the type of prop you are planning on using. I think the wrong propeller might give the motor more problems than the battery.
