MichiganFlyer
Started a new build this week, actually it is my first build. I was going to build a air boat for my 6yr old to have fun with then I thought Hydro Plane. So earlier this week I went to DollarTree and got some foam board. I had some left over pink board from a insulation thing and now it is coming together. I removed the paper from 2 sheets, added a couple spars and glued them together. About the tme I had the floats sanded to shape the postman showed up with my nichrome wire. Sweet! About 5 minutes later I had built a foam cutter. No Joke. Anyways my project is on its way and will hopefully be flying in the next couple of days. Foam cutter worked awsome for cutting out a canopy and a cavity for electronics in the fuselage.
